Compression Tester - What Size Fitting?
Old Jul 8, 2011 | 07:40 PM
Barfly's Avatar
Compression Test - Results
I'm buying a compression tester and need to ask "one of those questions"...
The tester comes with 14mm and 18mm adapters, will this work with my 340?
Thank you
Joe.
Old Jul 8, 2011 | 07:57 PM
scotts74birds's Avatar
14 bro, it would be the same one you used for the cylinder leakdown test.
Old Jul 8, 2011 | 08:16 PM
Barfly's Avatar
Thanks bud.
No leak down test, maybe your thinking of someone else.
Thanks again
Joe.
Old Jul 9, 2011 | 01:49 PM
Barfly's Avatar
'72 340. My '72 service manual says anything over 100 lbs is good with no larger than 40 lbs variance.
Cylinder Tested @
1 125
2 130
3 130
4 30
5 120
6 120
7 125
8 115
Knowing that I have a lot of oil accumulating in the air cleaner (w/ new PCV valve) and the engine temp is way up, does anyone think it is worth doing a leak down test? I don't have a leak down tester and would need to buy or rent one.
Thank you
Joe.
Old Jul 9, 2011 | 02:32 PM
blue 68 gts's Avatar
Cylinder Tested @
1 125
2 130
3 130
4 30
5 120
6 120
7 125
8 115
Thank you
Joe.
Squirt oil into that cylinder and see if the compression rises. If it doesn't then go for doing a leak down.
that dead hole is probably why you're having issues with trying to get it running good
Old Jul 9, 2011 | 04:30 PM
Barfly's Avatar
Thanks Blue
Just got done with the second test, this time with a cap full of oil in the cylinder. Jumped the compression test up to 50 lbs from 30 lbs.
Bummed out, I don't got this kind of money.........
Old Jul 9, 2011 | 05:18 PM
You are a good sport...you should have a on number 4 cylinder instead of
Old Jul 9, 2011 | 08:02 PM
Barfly's Avatar
Knowing there are so many variables it's hard to say, but what is a ball park figure for overhauling my 340 just using stock parts.
With the engine out of the truck what's a ball park, are we talking $100's, a $1000, more......
Thank you
Joe.
Old Jul 9, 2011 | 10:01 PM
Thank you
Joe.
If you are in good with your machine shop like I am I get the block bored...honed...decked...new cam bearings and freeze plugs and line bored for 500 bucks...the rest is up to me...a gasket set and some good crank and rod bearings and piston rings...all for under 1000 bucks....balancing the rotating assy is another 250 for me...70 bucks for Pete to turn the crankshaft...I do it enough to be good with everyone
vanman2
Sep 16, 2011 05:22 AM
Irish60
Sep 14, 2011 08:10 PM
scotts74birds
Nov 29, 2009 09:03 AM
Zach8200
Oct 7, 2008 03:05 PM
chargeruk
Sep 22, 2007 06:05 PM
