decoding numbers 727 trans.
I believe i have a 727 transmission but not sure if its a heavy duty set up or not. I was told it came from a truck. I cannot find any clear information thats cut and dry for me; can anyone help? Here are the numbers i found:
above the pan l-side 3640825 m4350 5131 on case casting l-side: 3743103-8 on tailshaft: 18 thanks, |
Come on someone can surely help.:)
thanks, |
About all I can tell you with any certainty is it was built June 25.1973. I'm still looking for more info on it.
I think after 69 they stopped stamping the VIN into the bell housing. I have the original case out of my dads GTS, has the VIN stamped. Had a 69 case, no numbers..
Thanks!
| All times are GMT -7. The time now is 08:11 AM. |
