Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   difference between 426 wedge and 426 hemi (https://moparforums.com/forums/f62/difference-between-426-wedge-426-hemi-9604/)
timmie124 May 23, 2011 06:53 PM
there's a guy around me selling a 426 max wedge with everything except a crank shaft for 300 dollars
im on really considering on picking that up but just wondering is there a difference between the hemi block and the wedge block? could i put hemi heads and pistons on a wedge block and it run like the real thing?
1962 dodge max wedge (1852029-1) engine in good shape was running when pulled. 413 punched to 426.
John Van May 23, 2011 08:34 PM
Sorry, no.
Unless you need the dated block,I would pass on this, The forged crank is the best part of this package.
john
blue 68 gts May 23, 2011 10:04 PM
john
Tell me where this motor is, ill buy it.
$300 IF its a 426 max wedge, pssh. Too much. ill give him $300 though
timmie124 May 23, 2011 11:17 PM
http://orangecounty.craigslist.org/pts/2352924180.html
heres the ad still wondering if i could i could do what i want to do with the block or not
TVLynn May 23, 2011 11:46 PM
two completely different blocks, although they do share bolt on parts. I 'm not sure what the heads are he says industrial heads . 1962 would be a 413 block bored to 426.... The 426 did not come out until 63
MercuryDon May 24, 2011 01:14 AM
Sounds like it maybe a Marine Engine to me. That would explain the industrial heads. The block number does come up as a 1962-63 413.
440roadrunner May 24, 2011 08:08 AM
max wedge.
This is a term that is getting WAY too much mileage. There never were very many "max wedge" engines, and there are far "too many" of them showing up.
If this really WAS a "max", and I doubt it, it would be worth way more than 300 bucks JUST FOR THE HEADS.
Max heads are a very very special breed, as are the intakes.
Chrysler made lots and lots of 413s and many more 426 stageI/ II "street wedges" than the stage III "max" wedge, and there were damn few of the last.
