Dodge Challenger Gears
Old Mar 26, 2011 | 03:52 PM
Masonmoret's Avatar
Exclamation Dodge Challenger Gears
Hello, I have a 1970 dodge challenger with 8-3/4 gears in the rear. I was wondering what is ur opinion on those gears, if there good bad? If there bad what would you recommend me changing them to.
Old Mar 26, 2011 | 05:11 PM
John Van's Avatar
Welcome to the forum, The 8 3/4 rear will be ok for even big blocks w/auto trans. A modified big block w/4 speed and sticky tires that 8 3/4 will surely be short lived, that's why ma mopar put dana 60's in w/440's,hemi's with 4speeds.
Old Mar 26, 2011 | 05:19 PM
I agree totally.. The tranny is the difference...... Several of the guys are running an 8 3/4 in their Drag Paks but all to date are autos.... JMO....
Old Mar 26, 2011 | 05:24 PM
Masonmoret's Avatar
Alright cool. I have a 4 spd so should I go buy some Dana rear gears?
Masonmoret's Avatar
With a strong 440
Old Mar 26, 2011 | 06:03 PM
Silverick's Avatar
The factory installed a Dana 60 for that set up.
Old Mar 26, 2011 | 07:24 PM
Masonmoret's Avatar
It's not stock. When I bought it, it had a 318 with a Colem shifter. Now it has a 4 spd with a 440.
Old Mar 26, 2011 | 08:19 PM
John Van's Avatar
Take off that 8 3/4 and sell it before you break it. See Cass also know as doctor diff, he can set you up with a good dana 60.
http://www.doctordiff.com/
john
Old Mar 27, 2011 | 07:25 AM
you can have the 8 3/4 built up to handle the additional power. that might be a cheaper route than finding a dana 60
Old Mar 27, 2011 | 09:23 AM
Masonmoret's Avatar
Thank you for all you help people!
Old Mar 27, 2011 | 01:33 PM
MercuryDon's Avatar
Unless you dumping the clutch the 8 3/4 should be fine. They did put the 8 3/4 behind Hemi Automatics so they are not a light weight rear. The Dana is stouter but is also heavier and more difficult to change gear ratios in.
Old Mar 27, 2011 | 02:02 PM
Masonmoret's Avatar
Yeah I looked that up. But I think I'm going wit the 60 Dana just because I don. Want problems
Hey another question,
On a dodge challenger what suspension would you guys recommend to be good and have a lowered stance?
78cordoba
Feb 21, 2009 02:34 AM
v6spitfire
Feb 18, 2009 10:54 PM
darkcrow
Oct 4, 2008 01:59 PM
debby440
Jun 18, 2008 11:55 PM
transman037
Jan 20, 2008 09:56 AM
