Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   Energy Suspension (https://moparforums.com/forums/f62/energy-suspension-2478/)
plymouthrr1985 Mar 6, 2009 07:01 PM
Energy Suspension
I was searching for rebuild kits on ebay for my road runner and came across a company called Energy Suspesion selling kits for lik $125.00, i was wondering if anyone has used them and if they are any good?? Thanks for the help.
theomahamoparguy Mar 6, 2009 07:47 PM
i havent used them personally but they have been around quite a while.
The mopar mags have used them in the past, cant remember any complaints. I think their noted for polyurethane kits, but they have anything you could want. What do you get for $125?
plymouthrr1985 Mar 6, 2009 08:00 PM
  • Front Upper Control Arm Bushings
  • Front Strut Rod Bushings
  • Front End Links Set
  • Lower Control Arm Bump Stops
  • Rear Leaf Spring Bushings
  • Tie Rod End Boots
This is according to the ebay site.
johnthegoalie Mar 6, 2009 08:26 PM
i have their polyurethane kit, bought it from a suspension shop in phoenix - no complaints
theomahamoparguy Mar 6, 2009 08:26 PM
That sounds like a pretty good deal for sure. Like i said, they've been around for quite a while. Some of my friends have ordered from them, non of them had any complaints. Do you not need the lower control arm bushing?
plymouthrr1985 Mar 6, 2009 08:28 PM
I would, but still for 125.00 i could get those somewhere and still come out cheaper than most companies.
theomahamoparguy Mar 6, 2009 08:41 PM
Yeah I hear ya! Good luck with the job. Doing front end work can be rough.
rr69half6bbl Mar 9, 2009 08:17 AM
Ive used their kits in several cars, the urithayne, veru happy with them. but you need to get the super kit, it has all the tie rod ends, upper and lower ball joints, tie rod sleeves, ipper control arm bolts and cams, rebound bumpers, upper and lower, sway bar bushings, adn lower control arm and strut rod bushings, if your gonna do the front end do it all save yourself some greif later, just my opinion.
