ethenol fuel what do you know about it .
i know you guy's run a fair bit of ethenol blended fuel over there . so how is it ? i want real answers not i just don't like it cause somebody told me it's bad . if you use it please tell me your expirences . ( look i know i can't spell but i do my best ) do you make mods to get the best out of it ?? the oil company's have everybody fooled over hear . i ran it for years in my 2lt toyota & it seemed fine that was only 10% ethenol though .
just my idea. EVERY engine running gasoline should use marvel mystery oil.
I know this from experience. It killed the carb in my Aspen. It made my Dakota stall. It plugged up the float needle valve on my Gran Fury. If you let the cat sit and don't start it very often the gas evaporates and leaves behind a gummy mess. I know run Lucas Oil's product that protects against this.
http://static.summitracing.com/globa...C-10670_xl.jpg |
a while ago i seen bell startron fuel enzyme for e 85 . it mixes the water so it doesn't seperate . or something like that . are there carb or fuel line mods so it works good .
Thus far I have seen no bad effects in my car or truck engines... But my small engines are a different story... I was constantly taking either the lawn mower, weedeater, edger or something to the repair shop... It was the gas they kept telling me.... We looked and found a marinia that sold ethanol free gas and that ended the problems.... Now several gas stations have the ethanol free but it will cost app .40 to .50 per gallon more... I pay it... Still cheaper than all the repairs... I also have seen that Stabil has a new ethanol blend... But I haven't tried that ....
boy you got that right about the small engines the fuel lines just melt away we change them all the time got a roll of supposedly alcohol resistant fuel line but it fails..
in the car, the carb boil overs are the only issue i got once the heat soak and the fuel boiling also when i park from a long drive on a typical Florida hot day the fuel tank boils away you can hear it rolling along any ideas on this? i'm thinking a small leak in the tank maybe the cap or the vent lines at the top? |
im lucky, a mini market chain here sells 91 super ethanol free.
If you actually drive your vehicle on a daily basis, you won't really have an issue with the available 10% ethanol fuel.
However, if you let your vehicles sit for weeks at a time, you'll need to add a stabilizer too keep it from drawing in moisture and eventually drying out and plugging up your fuel system :naughty: Here's what the carb on my 440 Drag Boat looked like after sitting for a few months without a stabilizer additive :puke: http://www.fuelslut.net/ihost/files/123/newboatcarb.JPG http://www.fuelslut.net/ihost/files/...wboatcarb2.JPG http://www.fuelslut.net/ihost/files/...wboatcarb3.JPG I pretty much had to chisel out all the sediment with a scraper :doh: Any engine I have that I know will sit for more than a few weeks without use, I run the fuel down as low as I can and run some Stabil through it, so the next time I use it, I have to fill up with fresh gas :o |
Originally Posted by 98 SNAKE EATER
(Post 103153)
However, if you let your vehicles sit for weeks at a time, you'll need to add a stabilizer |
ok thanks . was wondering as i haven't got my 383 running & unsure which way to go . mines only a weekend cop evader .
My 440/493 has a detonation issue that I am dealing with. I know a few certain ways to fix it, one being the tactic of mixing some race gas in with the 91 octane pump gas.
For about 3 minutes, I considered a conversion to E-85. NO thanks... The guys who "like" it say it is cheaper than race gas. Cheaper? Yeah, for NOW. Once the feds decide to remove their incentives, it goes back up by .50 cents a gallon. Want more bad news? It has a high octane, sure, but to use it, you need to use MORE of it. You need approximately 35-40% more E-85 to make the same energy as gasoline. This means that instead of getting 12 mpg, I'd get about 8. Yes, 8 miles to a gallon on a type of fuel that isn't always at every station. No, Thanks. |
got to be diffrent
I run 91 octane without ethanol and believe it or not I run 25% to 50% North Dakota crude oil. car runs great better performance, no carb problems or sparkplug problems. Yea most people might think I'm crazy and will burn up my 340, it does burn a little hotter but it has to be better than the crap at the pump. and no not all crude oil is thick and black. it comes in all sorts of flavors and colors.
Originally Posted by Fred340chrysler
(Post 122125)
do you really know what is in the crude oil you are running? i think the term crude oil is a very general term. and could mean all most any thing. it can have as much as 6% sulfur, and it has some hydrogen but the hydrocarbon chains are single chain meaning they will brake down easy. doing this for a short time is not much info. if you have done it for a long time with good results thats an other thing. EDIT: dont for get the Marvel Mystery oil. and check out the ampco oiler. http://www.ampcolubes.com/
(Post 122125)
I dont understand.... How does that work? What is it your using? Really!! Must be awfully thin Crude oil |
be diffrent
I work in the oil field I grade crude oil for Shell oil co. the crude oil I run in my car is very thin like thinner or like drip gas. the oil content is around 5% the term for the crude I use is called natural gasoline. It looks like and smells like gas use to look and smell like when I was a kid in the 60's. My car runs great although I don't run it every tank full and I mix it with gas. But my old 2 cycle dirt bike likes it straight. So if I burn up my dirt bike well it carried my old butt for all theses years I'll burry it with honors.
at the risk of repeating you self. try Marvel Mystery Oil in the fuel. and check out the ampco oiler. http://www.ampcolubes.com/
Fred..... Is that the oil you can put in a small cup and light it on fire and it burns kind of fast? I mean much faster than Kerosene oil?
I'm not to good with computer stuff so please bear with me I'm looking up the marvel mystery oil web site thanks I like new stuff . and yes I use crude oil to light my burn piles (wood and paper) depending on the crude oil yea some burns like diesel fuel and some burns before you can get the match close to it. I'm a nobody I just try to do things different, I've ran on used engine oil in my old diesel cars (in the fuel tank) didn't smoke bad and that was straight no diesel fuel so call me stupid it was fun. Bob I'd love to send you a sample of crude oil let me know how to send it to you
Originally Posted by 440roadrunner
(Post 122127)
You don't really expect anybody to believe this nonsense do you?
Thanks Fred....
I'll pass on you shipping it to me. I don't want anyone to get in trouble on My account... I do find it interesting that you have gotten that stuff to work as a fuel? Well.... Keep on Pumping those wells... :) Like my old pappy use to say... "Theirs earl in them hills" And money to be made.. |
| All times are GMT -7. The time now is 04:20 AM. |
