Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   Gauges (https://moparforums.com/forums/f62/gauges-2542/)
sgp7679 Mar 15, 2009 09:18 AM
Gauges
My coolant temp gauge and fuel gauge dosent work. I am wanting to just put a cheap temp gauge on and try to fix the gas gauge. What could make a gas gauge not work and how do i fix it and how do i install a aftermarket temp gauge? is it very hard?
johnthegoalie Mar 15, 2009 10:15 AM
not hard, but with all electricals - it requires time and patience to route the wires so they dont look like a bowl of spaghetti. electrical gauges need a wire to the sending unit, a hot and a ground as well as hot and ground for lights. mechanical only need the lighting but you have to route capillary line.
richinny Mar 15, 2009 11:45 AM
i'm not sure if applies to your year but.......
Chrysler used a voltage regulator on the back of the gauge cluster. the ones i remember had three flat blades that slid into the cluster board.
i'd start by checking the ground and battery feed to the gauges.
78D200 Mar 15, 2009 12:39 PM
It might not be your fuel gauge but your sending unit, same with your temp gauge, or it could be a broken/shorted wire.
67 GTX Mar 16, 2009 05:24 PM
same with me
my fuel gauge doesnt work
im pretty sure it is my sending unit
Crazy4Carz.Com Mar 16, 2009 06:37 PM
Originally Posted by 67 GTX (Post 15363)
same with me
There is a wire/clamp type thing that grounds the fuel sending unit on the fuel line as it goes into the tank. Check that, you may find your problem.
PS, it is not the wire on the sending unit. It is a piece of metal, like a thin strap that attaches the line to the sender.
67 GTX Mar 17, 2009 03:06 PM
ok thanks
i'll check on that
rr69half6bbl Mar 18, 2009 11:05 PM
quick test. with the key on put test light end into the plug connector for the tank sending unit, if the light blinks on and off repeatedly then the wire is fine from the gauge to the tank , it is an intermitent signal supposed to go on and off. if it stays on the wire is grounded somewhere from gauge to the tank , that wire runs from the dash down the drivers side floor pan to under the back seat then through to the trunk and down through the trunk floor under the spare tire. If no signal then the wires ither shorting out or the gauge isnt working, if the sifnals fine then its the graound strap crazy mentioned or the sending units bad.
