Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   Holley Carb Draining into Intake (https://moparforums.com/forums/f62/holley-carb-draining-into-intake-23814/)
lahatte Mar 25, 2021 03:59 PM
When I started my engine cold, it ran for a moment, then started to die, as if flooded. Going over to the front of the car I can hear the gasoline draining into the intake.
Anyone know why that might happen? I don't have reason to suspect a bad powervalve yet, but I'm still investigating.
Thanks.
Iowan Mar 25, 2021 04:10 PM
Holly neddle and seats have a tendency to stick when dirty, try giving them a clean and adjust the floats.
lahatte Mar 25, 2021 07:18 PM
I have replaced the front needle and seat already. I suppose maybe the rear one could have an issue. I haven't removed it yet.
I had leaking issues at the front and just replaced the accelerator pump diaphragm, which seems to have stopped that leak, but now I get fuel under the rear accelerator pump.
This carb was purchased 10 years ago from a rebuilder, and doesn't have a lot of running time on it. It had been great until I tried to start the car last fall and got the flooding issues.
Iowan Mar 25, 2021 07:49 PM
I've never had any luck storing carbs, i generally put a kit in them before I use them again after sitting.
RacerHog Mar 26, 2021 07:26 AM
I agree, all the rubber drys out and cracks, and will add to also check the floats to make sure they are also still good...
Archer Mar 26, 2021 08:22 AM
la -
Assuming the carb is intact (and I agree a rebuild might be in order), you did check the float levels, right (assuming a Holley)?
