Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   Intermittent starting problem. (https://moparforums.com/forums/f62/intermittent-starting-problem-23418/)
Jasman57 Aug 21, 2020 12:18 PM
My 1965 Plymouth Valiant occasionally won’t start. It doesn’t crank. The battery and starter are good. The radio comes on when you turn the key, but nothing at all happens with the engine. It has happened three times in three months. Each time the car eventually started and it would be weeks before it happened again. Any ideas what might be wrong?
Coronet 500 Aug 22, 2020 05:37 AM
Welcome.
Bad connections or start relay.
Jasman57 Aug 22, 2020 06:19 AM
I’ve worked pretty hard on checking/fixing possible problem wires but have not done anything with start relay. Thanks.
Skwerly Aug 22, 2020 11:28 AM
relay had me baffled as well on an old ramcharger i had. it's a good place to check out.
Jasman57 Aug 22, 2020 02:39 PM
Getting a new relay tomorrow morning. Thing that had me confused was the intermittent part. I wasn’t aware a relay could be failing without being totally broken. I guess we’ll see.
RacerHog Aug 22, 2020 06:44 PM
Check the Neutral safety switch and or Clutch switch.
Jasman57 Aug 22, 2020 07:11 PM
Check.
RacerHog Aug 22, 2020 07:17 PM
Not saying its not the start relay... Just a few other things to check on these old gals... :)
Jasman57 Aug 22, 2020 08:00 PM
What I was wondering, though, is if the clutch safety switch was broken, wouldn’t the car fail to start every time? The not starting problem has happened intermittently.
RacerHog Aug 23, 2020 06:03 AM
More like the switch hanging up intermittently.... That was my thoughts..
Jasman57 Aug 23, 2020 06:29 AM
Well, I bypassed the clutch switch and replaced starter relay. Will see how that goes. Thanks for your thoughts.
RacerHog Aug 23, 2020 03:21 PM
Keep us posted... :)
