Which Key? Ignition or Trunk...
Old Dec 29, 2010 | 10:11 AM
twalace's Avatar
Bought a 66 Dart with two keys, one opens the trunk & one works in the ignition. My question is which one is also to operate the doors from the factory as neither of them seem to be working...
Old Dec 29, 2010 | 10:53 AM
blue 68 gts's Avatar
The ignition key is the same for the doors. It could be possible its had the locks changed or the ignition changed.
The trunk key is all by itself
Old Dec 29, 2010 | 11:51 AM
Archer's Avatar
T -
The ignition/door key should have a pentagon head, the trunk key has a round head.
Like blue said, the cylinders might have been changed or he had new keys made.
Old Dec 29, 2010 | 04:53 PM
Or they might just be really badly gummed up. I'd try a squirt of just about anything that won't hurt the paint, including 'ol WD
Old Dec 29, 2010 | 06:19 PM
John Van's Avatar
If the key still won't work,just take out the door lock cylinders and bring them to your local locksmith.They can be keyed to fit your key.
Old Dec 30, 2010 | 01:50 AM
BuckNeccid's Avatar
Or, if you feel lucky, you can just pull the door locks and look at the sides. There's a flat plate that has like 4 prongs holding it on. Pop that plate off, remove the flat inserts, and you instanly have the locks working with any key. Most people won't just randomly walk up and try keys to see if they fit, so once you lock them, people just assume the doors are locked.
The inserts are numbered, and if you have one lock that works, and one that doesn't, you can use that to change the tumblers to the correct ones if you have a supply of inserts. I did that on one of my b-bodies, many years ago, but the last 3 I've built, I just pulled the tumblers, and never had anyone open the doors.
Old Jan 22, 2011 | 08:48 AM
twalace's Avatar
Great info! Took your idea but didn't feel safe with removing all the tumblers as you can just unlock the door with anything. I pulled all the pins and set three of the five to work with my key so I have more security.
1968_CHARGRT_440_FOR_SALE
Nov 5, 2019 04:04 AM
dhansen_69RR
May 22, 2013 08:38 AM
sm73charger
Jan 14, 2009 01:24 AM
65AzBel
Dec 18, 2008 06:03 PM
tish
Oct 24, 2008 06:51 PM
