It Lives!
Old May 30, 2010 | 11:32 AM
RROriginals's Avatar
It Lives!
http://www.youtube.com/watch?v=TqHOLj-1E84
Took a minute but it's running, I need to pull the brake light fuse, any idea WHICH one it would be?
Going to Advance to get a new battery, pulling that fuse and seeing if it starts up freely
Old May 30, 2010 | 11:34 AM
dodgenut7's Avatar
not sure which fuse it would be but you should consider getting a haynes manuel for your specific vehicle it will take you through a complete tear down and rebuild they are a excellent source of info
Old May 30, 2010 | 11:51 AM
Sgt. Veteran's Avatar
Old As Dirt
Awesome man that sounds pretty strong, sorry no idea which is the brake fuse - worse comes to worse just start pulling them one at a time till they go out and you have found it .....
Old May 30, 2010 | 11:54 AM
samuelcosmo76's Avatar
you can just disconnect the brake light switch if the light is stuck on. if you look on the pedal under the dash you'll see it.
Old May 30, 2010 | 12:01 PM
Old As Dirt
yep that works too just don't pull it out of ajustment or you won't have any lights when ya hit the brakes which = being rear ended
Old May 30, 2010 | 12:06 PM
Now you and check off box number 1.... Get it started!!!!! Congrats on getting er going........ Keep us posted on your progress......
Old May 30, 2010 | 01:02 PM
johnthegoalie's Avatar
thinkin with me dipstick
don't forget to re-tighten the air filter...
Old May 30, 2010 | 01:26 PM
blue 68 gts's Avatar
I'm not sure what loosening up the air filter, and having a dead battery is going to help but okay...
That battery is gone. Get an interstate
Glad to see its running
Oh, and for the fuse, look closely at the panel. Theres probably about 6 or 7 fuses. Each have a diff purpose. One will be for all the lights IIRC. Replace it
Old May 30, 2010 | 01:29 PM
^^ that's what i said hahaha
Old May 30, 2010 | 02:25 PM
Loosening the air filter actually helped it start up first turn. Just put a new battery in, tightened it, it didn't start, loosened it, it was fine.
Old May 30, 2010 | 02:26 PM
But one question, does anyone know WHICH fuse would be the brakes? I don't really want to pull them all
Old May 30, 2010 | 02:29 PM
if you take it off completely it might start by itself
look at your fuse block, it should say what each is for
Old May 30, 2010 | 02:30 PM
Haha, smarta$$, Atleast it starts first turn now. Want to enlighten me on my fuse?
Old May 30, 2010 | 04:06 PM
Crazy4Carz.Com's Avatar
Holy cr@p, It is taking longer to keep asking about the fuse than to just check each one. There is only maybe 8. How long could it take? 3-4 minutes?
Old May 30, 2010 | 05:45 PM
67gtxclone's Avatar
Glad you got her running! Man, that air cleaner thing is one odd
idiosyncrasy. Maybe your filter is plugged and not letting enough air in??? But no matter what, whatever works!!!
Old May 30, 2010 | 06:58 PM
Holyhell batman! Actually it has 11. And it was easier to just disconnect the connection in the trunk. Oh and to enlighten you a bit, the fuses did NOT want to come out.
Old May 30, 2010 | 07:01 PM
Of course they don't want to come out... old fuses, corrosion, tight fits, ect.
Just gotta find a way to get em out. Sounds like you got it though
Old May 30, 2010 | 07:16 PM
Yeah, theres no corrosion or anything, they just don't want to come out, at all. I used fuse pullers, needlenose pliers, clamps, screwdrivers. I just said "Screw it" and disconnected the lights until I get around to the fusebox
bullitt 736
Jan 31, 2012 03:50 PM
