mobile soda blasting
Is there a need for mobile soda blasting in florida.
how well does soda blasting work?
Very well, I am a mobile soda blaster in florida and I can strip a car in 3-4 hours of paint, body filler and grease and grim. You can see my work on face book under blast the past.
isnt soda blasting dusty? epa would have a hayday,,, i know soda blasting is one of the more gental preps on metal,
[quote=tesla57;48249], I am a mobile soda blaster in florida quote]
if you are a mobile soda blaster in florida you know you own answer ,,,,right? :p |
Dose it do well on rust?
soda blasting
With soda blasting I can do it both wet or dry. Dry blasting is very dusty but it is the most enviromentally sound method as far as the EPA is concerned. They performed a study and found it to be better than sand and chemical stripping. As far as rust I can remove rust to a point, surface rust is no problem but heavy scale is much harder. If any one is in florida and needs to have a car stripped I can be reached @ 407-495-7864
