Monaco stutters when I floor it...
Old 03-02-2011, 08:10 AM
Monaco500's Avatar
Hi all, I have been driving my dodge for about four months and everything seems to be working well except when I floor it (still getting over the lead foot) the engine cuts out just a bit at first then takes off like a rocket. Any ideas on what might cause this and recomendations on how to resolve it would be greatly appreciated.. Thanks
Old 03-02-2011, 08:31 AM
Silverick's Avatar
Sounds like it could be the accelerator pump in the carb. Is it a 383 with a 2 barrel?
Old 03-02-2011, 08:41 AM
Monaco500's Avatar
It's a 383 with a 4 barrel, thanks Silverick.
Old 03-02-2011, 09:20 AM
Silverick's Avatar
If it's the stock Carter.... it is an easy rebuild.
Does the car still have points in the distributor? If so, an adjustment or replacement may also help.
Old 03-02-2011, 11:42 AM
ryan's Avatar
My 440 does the same thing with the 750 carter on it its way more noticable when i have a rolling start and then floor it. I have read that because of the mechanical secondarys with no secondary accelerator pump and that it initially falls on its face because of a extremely lean situation once you get vacume back the engine starts sucking gas and takes off. I have read that a person can modify the weights on the secondary air plates(kind of like a choke for the secondary's i cant think of the technical name) to correct this problem but i have never done it. You could also try to change the nozzel size on the accelerator pump to get that volume of gas that it squirts in there a little faster
Old 08-24-2012, 04:34 AM
Monaco500-440's Avatar
My 440 Monaco does that too (66), i just cannot seam to ever launch it without bogging.. I rebuilt the factory 4-barrel carb but it still does it.. Any ideas?
Old 08-24-2012, 05:09 AM
Archer's Avatar
Gents -
It usually has something to do with fuel delivery, and "may" be the accelerator pump, or it may not... Could be as simple as an incorrect air/fuel mixture, vacuum leak, wrong size power valve, a dirty or clogged fuel circuit, etc.
A timing issue could be at fault too, but I don't think that's as common, unless the advance curve is way off.
I had VERY slight hesitation when the engine was cold. In my case it was too big a power valve and adding a 4-bore, 1" spacer under the carb helped a lot. (Single plane/open plenum manifold.)
Gorts 5th (08-24-2012)
Old 08-24-2012, 03:14 PM
Gorts 5th's Avatar
Smile
Originally Posted by Archer
Gents -
USUALLY when you mash it to the floor that hesitation is cased by a lean situation ie A power valve issue needs to open sooner or a weak accelerator pump sounds more like a power valve issue if its a carter u can get tuner kits for them that will give u a few options with power valve springs
Old 08-25-2012, 02:07 AM
mine hardly moves before the engine heats up.. It bogs right away, i strongly believe its as simple as an incorrect a/f ratio which i need to look into asap
bevelhead
01-23-2011 10:42 PM
crash dummy
09-10-2008 07:23 AM
miradaman
07-24-2008 05:59 PM
CoryOriho
05-17-2008 12:43 AM
rubadub
11-10-2007 12:34 AM
Quick Reply: Monaco stutters when I floor it...
