Thanks to all! I got the locking lug nuts off today!
:)Thanks to all! I got the locking lug nuts off today!
hammer on a socket that is a touch smaller than the nut. take off the nut and then get the nut out of the socket. thats how I have done about a dozen locking nuts with no keys or striped keys.
go to autozone and buy one? ive gone to lesswab and they have gave me one for a car i bought
If it's one of the round ones that you can't use a socket on, Weld a nut to the end of it, then use a socket on it. The heat from the weld will help loosen the nut before you try to break it loose. Weld thru the hole of the nut, make sure you have a good weld, and protect the wheel from splatter.
you can buy a tool to remove those. most shops have them too.
Originally Posted by richinny
(Post 10460)
Originally Posted by 78D200
(Post 10433)
You can cut a slot in the head of the lug with a grinding wheel then use a chisel to split the lug
Use a cold chisel and just tap it around works a treat
