Need help, found the cam I want but cant find the gear drive for it.
Old Oct 13, 2010 | 09:04 AM
1923tbucket's Avatar
The cam I need and want is a single bolt cam, all the gear drives ive found are all 3 bolt. Now all the 3 bolt cams seem to be requiring a higher compression or are really only effective around a higher RPM range and are kinda more of a race cam. So are there any single bolt gear drive sets out there? Just noticed I forgot to put that the motor is a 440.
Old Oct 14, 2010 | 03:33 PM
i think edelbrock uses single bolt cams
Old Oct 14, 2010 | 07:19 PM
John Van's Avatar
Why do you want the gear drive set? There is nothing wrong with a good chain set. just my .02 worth.
Old Oct 24, 2010 | 04:03 AM
Sangetsu's Avatar
Gear drives make that cool whine that sounds like a blower (at least the ones with the straight-cut gears). Personally I don't like a whiney engine, there are enough other whiners around.
Old Oct 26, 2010 | 07:14 AM
neonz1's Avatar
neonz1
What you are hearing is the wearing out process!
maca
Sep 28, 2013 08:54 PM
first64dodge880
Jun 20, 2010 02:56 PM
tice
Oct 16, 2009 03:31 AM
Chuck_S
Jul 10, 2009 09:15 PM
