Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   Need help, found the cam I want but cant find the gear drive for it. (https://moparforums.com/forums/f62/need-help-found-cam-i-want-but-cant-find-gear-drive-7759/)
1923tbucket Oct 13, 2010 09:04 AM
The cam I need and want is a single bolt cam, all the gear drives ive found are all 3 bolt. Now all the 3 bolt cams seem to be requiring a higher compression or are really only effective around a higher RPM range and are kinda more of a race cam. So are there any single bolt gear drive sets out there? Just noticed I forgot to put that the motor is a 440.
67 GTX Oct 14, 2010 03:33 PM
i think edelbrock uses single bolt cams
John Van Oct 14, 2010 07:19 PM
Why do you want the gear drive set? There is nothing wrong with a good chain set. just my .02 worth.
Sangetsu Oct 24, 2010 04:03 AM
Gear drives make that cool whine that sounds like a blower (at least the ones with the straight-cut gears). Personally I don't like a whiney engine, there are enough other whiners around.
neonz1 Oct 26, 2010 07:14 AM
What you are hearing is the wearing out process!
