Need help IDing Camshaft.
Ok so i was striping my old 400 bb and pulled out the cam and am trying to figure out if its stock or not. The car used to be a drag car so anything is possible. The numbers on the back end are 1094 and have C under it, also has green paint. Anyone have any ideas ive search high and low with no luck.
You'll have a hard time figuring that out. You need to measure the lobes to check for lift and wear.
But if it doesn't look NEW, replace it.... |
I am with Nick on this one. Throw it in the metal bin and get you a new camshaft. I tried several searches for you and had no luck.
Ahh ok thanks guys im thinking it was a stocker anyways. Im going to check out Comp Cams and Crane for one
| All times are GMT -7. The time now is 02:06 AM. |
