Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   need opions on making power (https://moparforums.com/forums/f62/need-opions-making-power-6853/)
Dartman91 Jul 11, 2010 08:50 PM
i have a 73 dart with a 360 it feels like its lacking power.. Im new to mopar so i dont know much about them i would apreciate tips on were to get the most power out engine
1966sportfury Jul 11, 2010 09:16 PM
dump the 360 and go to a 318!!
seriously tho, what was done to the engine? if its stock or close they dont have much pwr, due to lack of comp, and cams they are not much of a engine in stock form,
67 GTX Jul 12, 2010 10:29 AM
like 66 said, is there any work done to it?
MReeves Jul 12, 2010 05:15 PM
Bore it , stroke it and cam it!!!!!!!
Dartman91 Jul 12, 2010 08:53 PM
all it has is mild lunati cam with edelbrock single plane intake and a few other things that dont add power like stiffer valve springs also im looking into to buying a new carb whats a good size it has a 650 holley but im thinking bout going with a pro form thanks for the input
1966sportfury Jul 12, 2010 10:26 PM
no reason to spend $$ when you dont need to switching to a pro-form wont gain you any noticeable power, they both are very good manufactures, the single plane manifold will hold back power in the lower end most single plane manifolds are made to produce power at 2500+ rpm range, wile your manifold builds power to 6500-7500 the cam is out of power range, instead of buying a new carb, id either switch to a dualplane or invest in higher comp pistons, with a bigger cam to justify a single plane manifold
67 GTX Jul 13, 2010 05:02 PM
do you know what compression you are running now?
Tiretrack Jul 13, 2010 11:34 PM
You should probably swap out the single plane, that will raise the power band way up in the rpm range, and unless your driveing at Higher rpm's all the time, a duel plane would make it feel a bit more torquey at your normal drivring rpm range.
