Newby 1966 Plymouth VIP Axle ratio
Old Apr 14, 2012 | 12:45 PM
scott2683's Avatar
I'm looking to buy a 66 VIP and the owner doesn't know whether or not it is a sure grip, whats the easiest way to tell when I go to look at the car other than just smashing the gas and seeing if both tires break lose. Also does anyone know what gear ratio these cars came with? This one is a 383 4bbl.
Any help would be appreciated
Old Apr 14, 2012 | 05:31 PM
Archer's Avatar
Scott -
Chock the front wheels and jack the car up with a floor jack under the differential housing. With the trans in neutral, turn one back wheel. If the other ones turns in the same direction, it's a sure-grip/posi. If the other one doesn't turn, or (more likely) turns in the opposite direction, it ain't.
Most of those cars came with a 3.23 or lower gears. While you have the car on the jack, mark the drive shaft and turn the rear wheel again. See how many times the drive shaft goes around for every full rotation of the wheel. That will get you close to the ratio.
Old Apr 14, 2012 | 09:14 PM
scott2683's Avatar
Thanks for the reply Sir, I will definitely take your advice. I'm looking forward to checking this old fury out.
mattiedaddie
Jan 23, 2012 04:53 PM
D4NNYV8
Sep 12, 2011 06:52 PM
Charger_e55
Sep 2, 2011 07:55 AM
brawnerautomotive
Aug 30, 2011 03:43 AM
steve28529
Jun 16, 2007 08:13 PM
