Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   oil pressure problem plz help (https://moparforums.com/forums/f62/oil-pressure-problem-plz-help-1603/)
sixpackchris01 Oct 7, 2008 06:13 PM
I own a 1996 Dodge Ram 1500 5.9 liter When my truck is at running temperature and i'm idling my oil light comes on and after it idles for a minute my oil pressure drops to 0. I had 5W-30 in it and changed to 10W-30 to see if it would help and it did nothing. Alternator light is not on so idle is not to low. I also redid my valve cover gaskets because they were leaking a little.
Any Ideas????:confused: Thank You
78D200 Oct 8, 2008 12:55 AM
throw a mech gauge on the motor and see what that says. sometimes the electrical gauges and give you false readings.
