Older Mopar friendly mechanic in SE PA
Old Apr 16, 2010 | 03:22 PM
runrmc's Avatar
Junior Member
I'm having some trouble finding a older Mopar friendly mechanic in south eastern PA. I would prefer one in Chester county. Anyone know one?
Thanks
Old Apr 16, 2010 | 06:00 PM
Crazy4Carz.Com's Avatar
What do you need help with? I am in Delaware and maybe I can help.
Old Apr 16, 2010 | 07:21 PM
runrmc's Avatar
Junior Member
Getting an engine started after sitting.
Old Apr 17, 2010 | 08:31 AM
Polaradude's Avatar
What car, what motor, what tranny, how long has it been sitting ?
Old Apr 17, 2010 | 11:39 AM
runrmc's Avatar
Junior Member
1971 Fury 440HP about 3 years
Old Apr 17, 2010 | 01:56 PM
what have you done it it so far?
Old Apr 17, 2010 | 06:08 PM
I'd be glad to help you with that. Much of this will be easier on the lift. Drain and refill all the fluids. Gas tank, oil, coolant, etc. Then bleed the brakes. a quick once around with some grease, WD40, and then nut and bolt the car, you should be pretty much ready to go. Be sure the battery is up to the task. Take a sniff of the trans fluid, make sure it isn't burned or dirty. Wait to check the level until it is running in neutral.
Of course all of this is assuming that the car was running OK when it was parked.
Old Apr 17, 2010 | 08:22 PM
mopardrt's Avatar
make sure you check for rot under the car be sure to check frame to torsion bars is nice and heathy, i learned first hand that if its looking rusty under the floors/frame it only takes a short time before you have a broken torsion bar or another vital piece of frame
Old Apr 18, 2010 | 08:12 AM
runrmc's Avatar
Junior Member
Great, where abouts is your shop?
Old Apr 18, 2010 | 05:23 PM
I am sending you a private message.
Aquasition
Jul 12, 2014 05:56 PM
Rich Good
Dec 11, 2012 11:35 AM
KhaoticReign
Jul 14, 2011 05:32 PM
W3A8M3A
Nov 16, 2010 04:41 PM
outdoors724
Dec 15, 2009 04:02 AM
