por-15 paint
Old Jan 15, 2012 | 04:37 PM
scotty's Avatar
Question por-15 paint
going to do my floors with por-15 paint ,,its very costly,but heard its the best and will last forever,,has anyone here used it,and what did ya think of the product?and second any links to a good insulator to put down befor i carpet her.....thanks
Old Jan 15, 2012 | 04:57 PM
Joe's challenger's Avatar
Scott, I used POR-15 a lot on my camaro, I painted the engine, subframe, and the trunk pan, it works great- expensive and there is another item out that call RPM - http://ecsautomotive.com/rpm.php and here is a MOPAR thread about it- http://board.moparts.org/ubbthreads/...0&fpart=1&vc=1 I would look at this IMO. Hope it helps? As for sounderner I used HUSH MAT which was nice.
Joe
Old Jan 15, 2012 | 06:01 PM
mr340's Avatar
POR-15 works well, but if you get it onto any threaded holes you will need to chase them prior to installing a fastener. Failure to do so will result in broken bolts.
Old Jan 15, 2012 | 06:40 PM
scotty's Avatar
good tips thanks
Old Jan 16, 2012 | 02:51 AM
The surface needs to be clean of all debris and oils before putting it on.
Old Jan 16, 2012 | 07:39 AM
If you got surface rust or you are covering rust I think you need to remove any loose rust with a wire wheel first. It will come with some good directions on the can.
Old Jan 16, 2012 | 10:01 AM
scotty's Avatar
cool,,so no bad news on the stuff ,other than dont get it on ya ,,they dont make a solvent that can remove it it says on the can,,lol,,was over 50$ for a quart but its worth it i think
Old Jan 16, 2012 | 10:43 AM
moparted's Avatar
and it wont stick to clean, non rusted, metal unless u use the metal prep
Old Jan 16, 2012 | 08:27 PM
78doubleR's Avatar
yeah dont get it on your self anywhere. it will take weeks to get off your skin. i once got it in my hair doing the underside of a 65 mustang and had to get my hair cut.
Old Jan 25, 2012 | 05:24 AM
rdrunner1974's Avatar
POR 15
After reading the attached post, I went to Ace hardware and got some of the Rust Stop paint. I used it and it is just like POR 15. Available in many colors in pints, quarts and gallons.
Quite a savings at $10.00 a quart.
http://www.jalopyjournal.com/forum/s...ghlight=por+15
67 GTX
Jun 1, 2011 07:08 PM
beep1969
Dec 23, 2009 03:50 AM
Commando
Oct 23, 2008 08:37 PM
vitaminc383
Jul 19, 2008 08:22 AM
El Destructo Inc
Jun 11, 2008 11:18 PM
