radiator
I have a 72 cuda im building a 440 for should be between 400 500horse im wondering if there are recommendations for a radiator ive been looking at be cool one guy there told me they have one that will work another guy told me that a radiator that is a direct fit will not cool a motor over 400hp I find this hard to believe being they came stock with nearly 400hp
You need a 3 row 26" radiator of some type with a fan shroud Check if you can bolt the stock style 26" radiator in from an AC equipped model..
which radiator support do you have?
Originally Posted by TVLynn
(Post 104875)
He nailed it... |
I have a large Be Cool unit that stretches from frame rail to frame rail in my Dart with a 440. It better cool it good cause it cost me 750 dollars.
(Post 104875)
I would also run the Mopar Performance Viscous Fan, that's what I run http://www.summitracing.com/parts/dcc-4120758 |
