Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   Radiator questions..... (https://moparforums.com/forums/f62/radiator-questions-5943/)
67gtxclone Apr 18, 2010 08:36 PM
My 67 GTX clone (440) still has the 22in small block radiator in it and I am pretty sure I should change it out for the big block radiator before summer sets in. I have been looking on ebay and I see these Champion brand radiators which are 3 row aluminum for $219....seems like a pretty good deal. Anyone used this brand before? Any other suggestions for a replacement? I really want to be sure I do not have overheating issues later this summer.
1966sportfury Apr 18, 2010 10:42 PM
autozone has spectra brand 3 row for $206.. with limited lifetime warranty
Commando Apr 19, 2010 02:34 PM
My recommendation is to make sure it has the proper bracket on it, a lot of them are one size deals and then you have to bracket it up and could possibly lose some air flow.
67gtxclone Apr 19, 2010 02:43 PM
I will watch for that, thanks for the info. Do you all know if the cars back then were drilled for either mounting the 22 or 26 inch radiators, or for both?
To me, it looks like there are 3 holes down the drivers side, 2 on the passenger side, and the lower hose and petcock are on the drivers side and the upper hose is on the passenger side...do you all agree?
It does not really matter which side the petcock is on as far as I can tell, correct?
