Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   Rallye Gauges??? (https://moparforums.com/forums/f62/rallye-gauges-16498/)
74Runneer Jan 11, 2014 08:08 AM
Rallye Gauges???
Hey all I just was about to order a new voltage limiter for my 74 Roadrunner 318 from RTEngineering but then I realized that I'm not sure if I have rallye gauges or not. I originally thought it was a nonrallye dash because it doesnt have a tach but now after further research im thinking its a rallye dash because it has all circular gauges. Can anyone help me out here? Will the RTE IVR3 http://rt-eng.com/rte/index.php/RTE_limiter work? Is there anything more difficult with rallye gauges? Thanks
440roadrunner Jan 11, 2014 08:29 AM
I'm not sure about the 74s, and my Dodge manual isn't much help. I BELIEVE
If you have an oil pressure gauge and not a warning lamp, you have a Rallye Cluster
http://www.performancecargraphics.co...bodyRallye.jpg
74Runneer Jan 11, 2014 08:33 AM
Mine is the same exact cluster but with a different radio. So this is a rallye?
robs74charger Jan 11, 2014 04:49 PM
That's the rallye, the standard dash has a speedo that runs across the top of the cluster with only a gas and alt gauge added
