rims and tires help
i have a 72 duster that has stock rearenddoes anyone no the biggest slick i can run on the back like tallness and width wise thanks
just call ur local tire shop they will be able to help, just remember it has small blot rims when you purchase a set or wheels and without mini tubbing you wont be able to go to wild and crazy whithout running into problems will want to run a 15 inch rim my tires on my dart right now are 8 inchs with about 2 inchs to spair i dont see you getting more then 10 inch tires under a stock duster
duster -
Just a thought, unless you're already running a veyy steep gear ratio in the back, you might not want the tallest slicks you can get, you might want the shortest. Going with a smaller diameter will usually give you more rpms (like a higher number rear ratio) and give better clearance. Street tires are a different kettle of fish. Just a thought. Archer |
I'm gonna run 410s in the rear and prolly get some axels
