Squeaky Wipers
Hey guys.....the wipers on my dart are incredibly squeaky. I tried cleaning the window real good with windex, but it only got worse, and the blades are brand new. Any ideas?
thanks! |
Wipers
Try useing Rainex on the winshield, put some on the wipers also. You will need to use a buffing cloth to remove the haze.
x2 on the rainex
i just put in a jug of rainex washer fluid.....it made it worse!
ammonia and newspaper always worked best for cleaning windows. don't know if it would stop you squeaky.
just put a thick coat of axle grease on the wipers! same thing works for squeeky brakes...
(im only joking) |
Now i can't see! .....but the wipers don't squeak anymore.
Try using Old Dutch Cleaner http://i150.photobucket.com/albums/s...tchcleaner.jpg and 0000 Steel wool then rinse extra good then clean again with Stoner Invisible Glass cleaner. Use alcohol wipes on the wiper blades.
