ta and aar 6 pack heads?
Hello everyone,new here,i just purchased a 73 road runner with a 71 340,and the heads are both stamped with a u and a backward j,the research i dug up said these heads were only in 1970 340 6 pack aar cuda and challenger ta. Does anyone on here know if this is 100% correct?
The Only info I have is:
2531894 340 1968-1970 3418915 340 1970-1972 Should have 2.02 int. 1.60 exh. TA heads have offset intake rocker Arms and relocated pushrods to clear a larger intake port. |
The T/A-AAR heads were 915's that have the pushrod bores reamed out for the offset rockers. These were by no means a professional looking job, they look like they were reamed out with a power drill.
Can you post some pics of it? They are ta heads if they have a U or O with a J.
Originally Posted by Mr.Duster
(Post 69820)
thanks for the repleys everyone, if there was not a specific casting for ta heads why would there be heads with a u or an o casting? I myself only knew of 340 heads with x or j stamped heads until seeing these.
I will get a pic of my original 340 heads and all the casting marks also.
The book I have says the intake ports were larger than a normal 340 as well but does not give the specs.
| All times are GMT -7. The time now is 08:38 AM. |
