ta and aar 6 pack heads?
Old Jun 8, 2011 | 10:09 AM
408duster's Avatar
Hello everyone,new here,i just purchased a 73 road runner with a 71 340,and the heads are both stamped with a u and a backward j,the research i dug up said these heads were only in 1970 340 6 pack aar cuda and challenger ta. Does anyone on here know if this is 100% correct?
Old Jun 8, 2011 | 12:00 PM
MercuryDon's Avatar
The Only info I have is:
2531894 340 1968-1970
3418915 340 1970-1972
Should have 2.02 int. 1.60 exh.
TA heads have offset intake rocker Arms and relocated pushrods to clear a larger intake port.
Old Jun 8, 2011 | 03:10 PM
mr340's Avatar
The T/A-AAR heads were 915's that have the pushrod bores reamed out for the offset rockers. These were by no means a professional looking job, they look like they were reamed out with a power drill.
Old Jun 8, 2011 | 04:44 PM
Mr.Duster's Avatar
Can you post some pics of it? They are ta heads if they have a U or O with a J.
Old Jun 9, 2011 | 02:47 AM
mr340's Avatar
Not necessarily, Those are just casting letters. Look at the pushrod passages, they look like they were just hacked up (because they were) there was no special casting for 6 pak heads they used the the big valve 340 heads and just modified them.
Old Jun 9, 2011 | 10:05 AM
408duster's Avatar
thanks for the repleys everyone, if there was not a specific casting for ta heads why would there be heads with a u or an o casting? I myself only knew of 340 heads with x or j stamped heads until seeing these.
Old Jun 9, 2011 | 03:20 PM
mr340's Avatar
I will get a pic of my original 340 heads and all the casting marks also.
Old Jun 9, 2011 | 11:28 PM
MercuryDon's Avatar
The book I have says the intake ports were larger than a normal 340 as well but does not give the specs.
CudaBob
Dec 17, 2014 08:38 PM
dstuck
Feb 2, 2014 09:19 AM
ef8340
May 27, 2010 09:29 AM
richk2843
Jun 21, 2008 11:29 PM
rabys
Nov 25, 2006 08:46 PM
