Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   Temperature gauge (https://moparforums.com/forums/f62/temperature-gauge-3003/)
sgp7679 May 9, 2009 09:01 PM
Temperature gauge
I got a aftermarket temp gauge and the connector on the engine is not the same as stock, I heard you have to drill a hole, but is there another way?
theomahamoparguy May 9, 2009 09:31 PM
There should be several plugs in the manifold, heads or block that go into the water jacket, with a pipe thread adaptor you should be able to adapt something. I think you can get a aftermarket tharmostat housing that might work also.
Polaradude May 10, 2009 03:30 AM
X 2 on that.
