Tire wear
Ive always had the inside of my front two tires wear really quickly. I replaced all the ball joints and bushings and got it re-aligned and the inside is still wearing. When you look at the front tires compared to the back ones, you can see that they are negatively cambered. Ive had it realigned several times before to try to correct this with no solution yet.
Well, here's your parts! Moog, K7030 bushing/adjuster set
And here's how to do it! http://vintage.mitchell1.com/PClubDa.../V2D769005.pdf
Yeah, I know..... I RULE!!
If you know what negative camber means then you should know which way to go. One tip is before you loosen the camber bolts take a punch or chisel corner and mark the cam (big washer) were it meets the frame. This way you can go back if things go bad and move the front and back the same amount so you don't change caster. I have a gravity protractor to check degree of change, not actual book spec.Good Luck. (much easier with two people)
