Tires
After I got my alignment done on my car awhile back, my car was driving good and the wheels wouldn't squeal when i turn. Slowly over time the wheels star to squeal when i turn. now on any semi hard turn, the front wheels squeal. Could this have something to do with alignment? the car still drives nice and straight. The inner part of the front tires wear out after about a month of driving also.
Are the tires pretty worn out? That might be part of the problem.
no, they're not worn out. have pretty good tread on them. air pressures right.
caster/camber
how are the front end parts?
bushings? |
im not sire how to check the caster/camber. It has new ball joints. i havent replaced the upper control arm bushings yet.
Originally Posted by sgp7679
(Post 48719)
the bushings could be worn out
if so, they won't hold the adjustment |
Could it be that we are just driving on warmer pavement now?
