Trying Decode Motor Plate Numbers E 440
Trying to figure out what type of car my 440 came out of. Currently in a 1969 Dodge Charger RT. I strongly believe motor is original but not certain. Marked on Block Vin Pad E 440 12 16HP2
Also trying to figure out if I need a weighted stall convertor or a non weighted convertor for that motor. I would appreciate all help. Thanks Ben |
Check All weights are located and tack welded on the torque converter ...
the Use a flex plate with the balance built into it. Then you can use any converter http://www.moparengineswest.com/Stampings.htm |
Look on the bottom right side center of the block, close to the rail where the oil pan meets the block. In '69, if it's a numbers matching engine, you will see at least a portion of the serial number on a flat machined pad. If the serial number matches, then you have the original engine in the car.
The E440 IS correct for a 69 model car, so you just might be right |
