turbo or supercharger??
Old Feb 16, 2011 | 11:34 AM
bugy's Avatar
Wink turbo or supercharger??
I got a plymouth prowler 2000, i wanna know if there's a super or turbocharger for it. does anybody know something?
Old Feb 16, 2011 | 04:34 PM
maddawg57's Avatar
Old Feb 16, 2011 | 05:54 PM
what engine are you planning on using?
Old Feb 17, 2011 | 07:49 AM
bugy's Avatar
the stock one, i think it is 3.5L v6 with 10:1 compression ratio
Old Feb 17, 2011 | 02:46 PM
i've never heard on a supercharger going on that motor, but im sure if you google it you can find someone who has tried it
Old Feb 17, 2011 | 06:15 PM
Crazy4Carz.Com's Avatar
10:1 is quite a bit of compression for forced induction, especially on a stock engine. If you do decide to go either way keep it simple keep it safe around 5 or less pounds of boost. Your engine compartment is very tight already i don't know where you are going to find room for either option, but I would guess the supercharger would be your best bet.
Old Feb 17, 2011 | 08:12 PM
blue 68 gts's Avatar
I wouldn't run forced induction on 10:1 either...
Old Feb 18, 2011 | 04:07 PM
scotts74birds's Avatar
Heres some chat I found on a Prowler forum that will help you. http://www.prowleronline.com/ubb/For...ML/003136.html
Old Feb 18, 2011 | 05:40 PM
rcknrolfender79's Avatar
10:1 compression is a ton of compression for forced induction. You can probably find a turbo to work with your motor if not I'm sure you can make one work, but your probably gonna have to pull that motor apart and put some lower compression pistons in it. Most small superchargers and turbos boost you about 4 to 6 pounds and thats going to be way to much with 10:1 compression and a cast bottom end. It would still be a bit scary with a forged bottom end. But thats just my 2 cents worth
Old Feb 18, 2011 | 08:13 PM
Silverick's Avatar
I read the post, googled it and there are a number of listings for this modification.
Old Feb 19, 2011 | 10:24 AM
bugy's Avatar
thank you for supporting
bugy
Aug 26, 2013 10:24 PM
Dominic Torreto
Jul 6, 2012 12:04 PM
jjg73
May 17, 2010 07:45 PM
st33l3rf4n
May 28, 2009 08:56 AM
ameyrick
Sep 8, 2008 08:28 AM
