turn signal lights won't work on my 69 383 magnum fuor speed charger
the problem with my 69 charger is head lights, running lights, brake lights all work but, neither left or right turn signals work. even if i flick turn signal arm up or down by hand.
Did you check the flasher and or fuse? ... start with the simple stuff, check for power with a test light
| All times are GMT -7. The time now is 04:43 AM. |
