We are under way!
Tonight we pulled apart the 8.25" 3.55 rear end I bought at the Salvage yard.
Saturday we will pull apart the 8.25" 2.71 rear end that's in the truck and swap out the gears. Pictures tomorrow of the damage so far ;) It feels great to finally be under way! Friday Night is the Start of "Mopar vs. The World" at the drag strip and continues Saturday evening. You never know, maybe :D Joe. |
How do you tell the gear ratio on an 8.25 without pulling it apart (if you can)? And can you tell if its a suregrip?
Just make sure that you set pinion depth, pinion depth preload and the proper backlash. Can't wait to see pics.
Originally Posted by tang72
(Post 51042)
You can also read the tag on the diff cover though. IF the suregrip is not worn out, then both tires will spin in the same direction. |
Here are some pics from last night.
http://i802.photobucket.com/albums/y...00721-1909.jpg http://i802.photobucket.com/albums/y...00721-1855.jpg http://i802.photobucket.com/albums/y...00721-1825.jpg And Tim, I will be sure to get all of that right, just as soon as I find out what it all means LOL |
setting backlash, remember i told you about the Prussian blue? thas what you will need it for, make sure the mesh correctly,
Okay time to fess up! :)
Here's the plan as it stands right now. We removed the carrier and bearings as one piece and left it that way. And then removed the pinion. The plan is to do the same on the other diff and swap in the entire carrier assembly with ring gear, spider gears etc... attached. I know it all sounds to simple to work right and I'm fearing the "oh waits" and "don't do that's" but that's the plan as of right now :eek: Joe. |
