What is a...
Stroking a motor is simply changing the length of the stroke. If you make it longer the displacement increases and bigger inches usually equals more HP. If you have two motors that are equal except for bore and stroke, the one with the longer stroke will make more torque than the short stroke motor. The short stroke motor however will rev quicker because the slugs have less distance to travel. Harleys are pretty long stroke motors, typically, this is why they have stump pulling torque. I've seen a Ferrari motor in a museum that had 4.250 diameter pistons and a .750 stroke! You'd have to rev the living **** out of it. Some stock car guys de-stroke (shorter) their motors and rev them higher. You can change the stroke by changing combinations of pin height, rod length, journal position etc...
Hope that helps.
god bless google
Hope that helps.
god bless google
on
Thanks guys, I now know I won't be 'stroking' my motor anytime soon. All that is a little out of my reach.
I sure appreciate the explanation tho. I've been doing a lot of reading and this comes up now and again but never with an explanation.
Thanks again
Joe.
Thanks again
Joe.
