What do i need for decoding
Old May 20, 2009 | 03:15 PM
Zach8200's Avatar
i decoded my vin tag on my road runner how do i know if the engine is numbers matching or not i got a number off the side of the block is that the number i need
Old May 20, 2009 | 03:36 PM
Red Devil's Avatar
Little Demon
what is the vin and fender tag numbers?
Old May 20, 2009 | 07:29 PM
Zach8200's Avatar
RM23 H26 186262 is the Vinfender tag 26 END G11 H51 M21 N23 N40 R11 V1X U 841 B51 C16 C56 EV2 D6X9 TX9 410 231611 E55 D34 then the vin at the bottom then i found 2780930-340-7 on the side of the block then a big 4
Old May 20, 2009 | 07:44 PM
blue 68 gts's Avatar
I believe the casting number on the block matches the sequence number in the VIN.
-nick
Old May 21, 2009 | 04:18 AM
rr69half6bbl's Avatar
there`s a machined surface just above the oil pan rail on the pass. side of the block, your vin, will be stamped into the pad, from the year on like9A11111 if the numbers match your vin, its numbers.the trans has the same thing on the pass side just above the pan.
Old May 21, 2009 | 12:24 PM
Zach8200's Avatar
cool its all there matching block and trans bad news i found my grill insert in two pieces and they dont reproduce them yet and there out of my price range to get another original
thepickupplace
Cuda Specific Discussion
Jun 29, 2013 09:18 AM
73plymduster
Aug 15, 2010 10:21 AM
plymouth
Aug 5, 2009 01:49 PM
piratemike
Sep 22, 2008 08:25 PM
70chargerrt
Jun 20, 2008 12:48 AM
