Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   what is a thick head gasket for a 360 (https://moparforums.com/forums/f62/what-thick-head-gasket-360-a-17576/)
maca Jul 23, 2014 03:27 AM
Hey all
I need to get more piston to valve clearance in my 360 magnum. My gasket has .042 compressed thickness. I need at least .060 compressed thickness as a minimum. I cant use a cometic as I tried one and it leaked oil. The head was shaved but the deck was not decked so I want to stay away from cometic.
Any suggestions
cheers Maca
RacerHog Jul 23, 2014 08:11 AM
Sounds like the piston valve pockets need to be opened up for the clearance. Unless your having a head to piston quench problem?
DodgeAddict Jul 23, 2014 02:51 PM
Try a thick dead soft copper gasket or paint a cometec with copper seal or high temp aluminum paint to make it seal
maca Jul 23, 2014 09:30 PM
Thanks guys
I ended up pulling the pistons out as I will be putting in a lower comp set eventually anyway. So just means I have to do it early.
Cheers
Ps, hey dodgeaddict are you also on the Australian site mopar market.
I think I may have chatted to you there before.
DodgeAddict Jul 24, 2014 09:38 PM
Originally Posted by maca (Post 121739)
Thanks guys
Cheers
Yes I am, & yes you have along with Ray & the others
I started the thread about Magnums there & model cars & such
Great site, I'm proud to be a member there
Bob
maca Jul 25, 2014 01:23 AM
Thought I recognized ya.
I am looking at supercharging my magnum but am reluctant to pull down my current engine as I have done so much to it. I am just doing some costings and want to know what a high mileage 360 magnum would be from a junk yard?
DodgeAddict Jul 25, 2014 08:47 AM
I pick them up for between $200-400 usually off the Craigslist
