1965 Plymouth Belvedere 1 4dr sedan--$3800 or Best
Here is what it has:
318/904 and drive shaft from 78 Magnum. Has towing cam and 650 Holley. It has a Koss CD/MP3 Player and a DVD player for the back seats. I just replaced: Front Wheel Cylinders Headlight switch Fuel Pump Fuel Filter Brakes Granted it needs a couple of things and has a few issues. They are: Heater switch Speedo Drive Driveshaft Lengthened by 1 inch Instrument panels do not light when switched is pulled out (new switch just installed) Vent window pivot drivers side. Included with sale: Holley 650 (needs rebuild) Original 273 (needs rebuild but complete from airbox to oil pan). 3 speed bell housing and flywheel Headliner material Carpeting for trunk A/C parts (just 1 part needed) New Speedometer cable Pictures can be found here: http://picasaweb.google.com/alex.doerstling/Belvedere# Price: $3800 or best. Will consider trades. Oh I almost forgot: This has been in Arizona all its life. It does have some surface rust on the paint but it is solid. |
Speedo Drive has been ordered and should be installed by the weekend along with a new letter set for the trunk.
