1969 Plymouth Road Runner Convertible
Old May 18, 2011 | 06:18 PM
Courtney's Avatar
Wheelbase: 116 inches
Overall length: 202.7 inches
Base curb weight: 490 lbs
Engine: 383 cu. in. V-8
Bore and stroke: 4.25 X 3.38 inches
Compression ratio: 10.0:1
Brake horsepower: 335 at 5200 RPM
Torque: 425 ft-lbs at 3400 RPM
One of 1,111 ever produced, this 1969 Plymouth Road Runner Convertible has undergone a total frame-off restoration. The original "383" was completely rebuilt to factory specifications, fitted with polished and ported heads and then fully balanced and blueprinted. The transmission was completely rebuilt and the rear end was rebearing. Suspension was restored with new springs, shocks, ball joints, tie rod ends and upper and lower control arm bushings. The brake system is new from front to back including all lines and hoses. The exhaust is a 2 1/2 inch with dual Dynaflow mufflers. Mechanically, everything on this car has been restored to new condition.
The body was completely stripped to bare metal and any rust was cut out and replaced with new metal. The finished body was professionally block sanded and refinished in the original color using the renowned Sikkens paint process. This has produced a show quality job with no considerable amount of filler. The convertible top is new, as well as all weather stripping and rubbers. The bumpers have been re-chromed and new body chrome moldings, door handles, etc have been installed. New correct Magnum 500 wheels finish off the exterior. The undercarriage was also painted and detailed to show standards.
The interior has had all painted surfaces refinished and a new carpet and door trim panels installed. The console has been restored and the original seat upholstery is in good condition with no rips or tears. Complete detailing has also included the trunk with a new trunk mat and repainting.
Muscle cars have seen very volatile pricing in the past couple of years and this market is just now starting a fresh rebound in value. No expense has been spared on this quality restoration of a most desirable, matching numbers Road Runner convertible and it is valued accordingly.
For sale by owner - $55,000 Canadian. Contact Terry at (780) 475-9043 or (780) 203-5384. Located in Edmonton, Alberta, CANADA.
Attached Thumbnails 1969 Plymouth Road Runner Convertible-sam_0375.jpg   1969 Plymouth Road Runner Convertible-sam_0377.jpg   1969 Plymouth Road Runner Convertible-sam_0378.jpg   1969 Plymouth Road Runner Convertible-sam_0379.jpg
Northerndave
Jun 20, 2013 12:15 PM
1969RR
Jul 20, 2010 04:19 AM
MOPUP
Jan 16, 2010 09:28 AM
martj
Jun 30, 2009 05:55 AM
MoparSon
Apr 15, 2008 10:09 AM
