22" 1968 Dart factory air 3 core Radiator
Old 12-02-2010 | 11:19 AM
22" OEM Radiator, 3 core heavy duty for A/C use
This is the original 22" 3 core radiator that came out of my 1968 Dodge Dart...it was for use with a fan shroud in a factory air car..it has been rodded out and two small cracks were repaired...it tipped over and fell and cracked two of the tubes...it is in very good condition and I would buy it to keep your car factory matching..
$200 bucks plus shipping
Old 12-02-2010 | 02:35 PM
blue 68 gts's Avatar
In my opinion... $200 is WAY over priced for an original one that needs to have quite a bit of work done....
You can buy a brand new, 3 core aluminum radiator for $250...
Old 12-02-2010 | 02:57 PM
Tighten up....young nick...it has been repaired...all it needs is a little paint....250 bucks won't get you the part number and pentastar on top of the tank...this is for someone to replace a missing one in a car they are restoring..try to get one made out of copper and the price is 400-500 bucks...I know I have one of those also
Old 12-02-2010 | 09:02 PM
heres the star....
Old 03-30-2011 | 01:58 PM
Geoff's Avatar
Question acadian
Hi, do you still happen to have that rad, I'm restoring a 68 Roadrunner, even though the numbers arn't right a three corethat looks correct might be my best bet. Do you happen to know if the height would be the same for both A and B bodies. Thanks
Old 03-30-2011 | 02:03 PM
As long as your Roadrunner used a 22" wide one it will work...22" radiators were all the same width and height..
mrzods13
03-19-2014 04:41 PM
mystarcollectorcar.com
04-16-2010 04:42 AM
plymouthrr1985
04-01-2009 04:29 AM
CadVetteStang
11-19-2008 06:32 AM
BB1
12-09-2007 12:36 PM
Quick Reply: 22" 1968 Dart factory air 3 core Radiator
