22" 1968 Dart factory air 3 core Radiator
3 Attachment(s)
22" OEM Radiator, 3 core heavy duty for A/C use
This is the original 22" 3 core radiator that came out of my 1968 Dodge Dart...it was for use with a fan shroud in a factory air car..it has been rodded out and two small cracks were repaired...it tipped over and fell and cracked two of the tubes...it is in very good condition and I would buy it to keep your car factory matching.. Attachment 17604 Attachment 17605 Attachment 17606 $200 bucks plus shipping |
In my opinion... $200 is WAY over priced for an original one that needs to have quite a bit of work done....
You can buy a brand new, 3 core aluminum radiator for $250... |
Originally Posted by blue 68 gts
(Post 59492)
1 Attachment(s)
acadian
Hi, do you still happen to have that rad, I'm restoring a 68 Roadrunner, even though the numbers arn't right a three corethat looks correct might be my best bet. Do you happen to know if the height would be the same for both A and B bodies. Thanks
Originally Posted by Geoff
(Post 66023)
| All times are GMT -7. The time now is 10:46 PM. |
