big block engines ,383-440,413,400,
ENGINES
1965--383 cast 6-7-65 block & steel crank 250.oo 1965 383 clean turns over dated 6-16-65 500.oo 1968--383 cast 12-28-67 assy 1-18-2 non h.p. block &steel crank 1969---383-cast3-3-69 assy 3-21-2 block&steel crank 250.oo 1969--383 cast 4-23-69 block& steel crank 250.oo 1970 383 long block dated 10-10 69 H.P. -blockrods&steel crank 450.oo 1971--383 cast 4-19-71 non h.p.block only 250.oo 1971 --383 cast 11-18-71 non h.p. block & steel crank 250.oo 72 440 complete motor steel crank ran when pulled 750.oo late model 440.short block, steel crank , from truck----siezed from sitting 350.oo late model 440 ,short block, cast crank siezed from sitting 250.oo 66 440 block .o4o over 150.oo 65 413 block dated 4-2-64 no caps 100.oo 62-67 383 iron intake #2205968 100.oo 67-69 440 intake # 2806178 i have the following dates 5-18-68 10-11-67 100.oo 66 440 intake # 2206000 100.oo 65 413 intake # 2206000 100.oo 68-9 383 h.p. intake #2806301 70 440 iron intake #2951736--dated8-23-69 125.oo 71 383 iron intake #2951666 100.oo 72 factory dual plane iron intake#3614014 25.oo medium rise single plane alum intake 413-440-100.oo VALVE COVERS 68 set -125.oo blased/primed 65 set-125.oo blasted primed 72 set 100.oo-blaseted primed no 70s big block water pump housings original iron diff cast #s avail. 67-70 383-hemi water pump housing #2780987--50.oo big block power steering brackets 50.oo big block pow st pump with brackets ,.blasted painted, 100.oo big block 4 groove crank pulley for steel crank 40.oo big block steel crank 2 groove crank pulley 40.oo big block water pump pulley for steel crank motor 40.oo air cond pulley and bracket for big block steel crank motor 40.oo non h.p exh. manifolds 40.oo pr many to chosse from stock rocker shafts 10.oo ea stock rockers 10.oo-set stock rocker spacers 10.oo-set stock bolts and special spacers 10.oo set mkyman@hotmail.com |
