Kelsey Hays front Disc (with rebuilt front end)
Attachment 2702
Attachment 2703 Attachment 2704 Attachment 2706 Had some issues with uploading all of the pictures. they are also avaiaable at: http://www.forabodiesonly.com/mopar/...730#post988730 Dodge Dart Front disc brake small bolt pattern 1967, 1968, 1969 may fit others Kelsey Hayes front disc brakes and front suspension completely rebuilt calipers with new Stainless Steel cross over tubes, painted with high temp paint, Refinished UCA and LCA with new bushings, upper & lower ball joints, in and outer tie rod ends, Inner and outer bearings and races, new inner seals, poly lower control arm bussing and new stainless steel pivot, new rotors, new shocks, and proportion valve - $800 I don't have boxes to package this entire front end so it is only available for local pickup. I you require shipping of this hard to find item I will work with your shipper but the purchaser is responsible for all shipping and packing cost of the carrier. |
