Need 2001 Ram 1500 4x4 Stub Shaft
Anyone know where I can get a replacement stub shaft and castellated nut for a 2001 Ram 1500 4x4 with a Dana 60 front axle? I had to heat the original to get it apart and want to replace it with something that still has the temper in the metal. The OEM part numbers are:
Stub Shaft 05015138AA Axle Hub Nut 04746773 I'd also like to try to find the bolts for the bearing hub. The part numbers for those is 04746775 Thanks, Tim |
| All times are GMT -7. The time now is 05:22 AM. |
