real Fast and Furious Dodge Charger Hemi + Blower
hello Guys .. i have buyed the next week the 1970 Dodge Charger used in the first scene of The Fast and Furious certified from Hollywood and cinema vehicle .. anyone know this car ? i have buyed from a swisse man that have buyed in Mecum auction in Monterey in august 2009 ... Engine is 528 HEMI with Blower and nitrous oxide system ..Electronic fuel injection the idle -down up-down up-down ... very difficult to drive when you put the first speed or reverse ... this is the video
That is way Cool
(Post 120876)
That is way Cool
I have no idea. Sounds like a NOS solonod is leaking
Originally Posted by TVLynn
(Post 120879)
I know a lot of blowers make them run like that....I have been to many tractor pulls and they all seem to idle like that.. My guess is that they are running a lot of fuel as to not melt down the pistons.. I would check with guys that deal with superchargers and see if they know why.. You could always tone the charge down by changing the pulleys and running lower boost...There aren't to many people running blowers on the street not like that anyway...Bill
Yes Raffa. I do know of the car.
That articulations is caused by ether the cam profile or the barrel valve adjustment. That's power baby!!!!!! |
Originally Posted by pro-tech
(Post 120881)
That is a nice car, but what you are experiencing is blower surge. As Bob stated, it can be tuned out to a large degree, but as it was in the video it is excessive in my opinion. You need someone that knows blowers to change the pills and tune the system. It will be a lot more streetable with a proper tune. As it is now, it's really only good for full throttle applications. Does it calm down when it warms up?
Originally Posted by Boat Guy
(Post 120915)
Raffa
I have "heard" blower car racers say this is a lean fuel setup condition to keep the idle down while still being able to hold the car (stage) with a tight converter in gear on the brakes, as they do not wish to loosen their converters for their race applications. The engine idle hunting is the engine looking for more fuel. Put a stick in it whoohoo !!! Cheers Peter |
I agree with the convertor being to tight..
Originally Posted by Drag Pak
(Post 121122)
Raffa
from "The Blower Shop"
This is caused by a rich/lean cycle at idle. As the motor leans out the RPM's increase and richen up the motor, when the motor richens the RPM's decrease and the motor leans out again. This continual cycle is known as "blower surge". With proper tuning, some of this surging should be able to be eliminated
Try turning the idle up and see if that makes it better???
Sometimes that's all it takes... |
Yes .. Think the cause is the idle mixture ... If i pu the idle at 2000 rpm ... No surge ,,,
Maybe you should look at the date of the post... I just don't get it.. Why people reply to old posts... Some as much as 3 years old...:slap: This one is over 4 months old..............
Cause we only chat here once in a while..... Raffa is a busy busy guy.... He does awesome work over there in Italy..... :)
Hi Guys ..i have adjusted idle mixture from Ecu at 1700 rpm .. A little bit better ...less surging .. Now im working for change the axle ratio .. And install the line lock on the brake ...i will try the car on the strip like that .. Car weight is 3900 lb with over 1000 hp ..rear axle is Ford 9" 35 spline with Competition engineering traction bars .Thank for your help
14.5 X 32" Tire ????
4.30 Rear Gear ????? 4000 RPM Stall Converter (Continental , The Converter Shop , ATI ) ????? Hop it dose well..... Keep us posted.... |
(Post 124629)
4.30 Rear Gear ????? 4000 RPM Stall Converter (Continental , The Converter Shop , ATI ) ????? Hop it dose well..... Keep us posted.... 528 Hemi blower 970 HP + 250 nitrous 275/60/15 MT drag radial dot pro Ford 9" currie with wawetrack and 3.73 ratio Transmission 727 full manual + john cope v bodie Tci 4500 rpm converter stall , 9" diameter |
Toretto's car is a nice build you guys are doing... :)
I think the car will MPH good out on the Big End of the track.... But with the 3.73 rear gear, I think it's going to be hard to get the big girl to move to the 60' mark... But if he is going to do allot of street driving? that gear is a nice one.... Just my 2 cent Keep us posted... :) |
(Post 124660)
I do not know how it will behave ' on the street ... This is the first race for this car ...
Keep Us posted....I'm sure with you driving.... It will do just fine.... :)
This is the specs ..no more modification on this car .. I have the race in May 2015 .. Im very curious ... Which ET of this car for your opinion !!??
975 hp without nitrous ( i dont think active in the first race ) I think only adjust valve ... Runs very good .. 3.73 with 275/60/15 MT drag radial pro 28" diamater 3800 lb weight 727 modified all billet with john cope v-body Comp engineering traction bars Ford 9" wawetrack Im working for install AFR electronic gauge |
