Mopar Forums (/forums/)
-   Non-Mopar Tech Questions (https://moparforums.com/forums/f67/)
-   -   ford 390 help (https://moparforums.com/forums/f67/ford-390-help-8641/)
luke Feb 4, 2011 06:53 PM
ford 390 help
1 Attachment(s)
My brother is finishing up his 390 for his 65 Galaxie. I know its not a Mopar but I was hoping someone can help. We have the 390 all together but he went and ordered a SFI Fluid Crankshaft Balancer as the org. one fell apart. The new harmonic balancer is wider then the stock one, how do I get the pulley to line up with the water pump or is it just not going to work?
thanks
Attachment 17209
http://www.freeimagehosting.net/uploads/be4fbd4a8d.jpg
MercuryDon Feb 4, 2011 07:08 PM
You might look here. http://www.network54.com/Index/10214
Silverick Feb 4, 2011 11:27 PM
Mercury Don makes a good point!
What I will add:
Is it seems to me that the simple fix is to find a water pump pully with a different offset. I'm sure that you're not the first person with this issue.
Is your brother building this 390 to TRY to keep up with a Mopar 383?
luke Feb 5, 2011 09:36 AM
What I will add:
Hope not 390 vs 383. :) The 390 I feel was best used in trucks. I would have run a different big block but he wanted "all org. " thing had a 351 when he got it told him to just stoke that small block.For the pully they do make a universal shim kit from summit to space they pully . Sleeping on it, I think he should just go to a shop with the waterpump gasket trace it out on 1/4 thick sheet, cut it and drill 3 holes. Putting the new spacers between the block and waterpump to move it out.This way the pump gets moved out not the pulley and wont put extra stress on the water pump bearings.But perhaps Iam wrong as everyone just tells me to move the pulley. Maybe Iam just way over thinking the whole thing. I just want everything to be perfect
MercuryDon Feb 5, 2011 11:04 AM
Nothing wrong with a 390. Most have 2.75-3.00 Diff gears behind them. Mopars most often run 3.23s altho some 2.76s are around in non-performance vehicles.The big Fords were also a few hundred pounds heavier than their mopar and chevy counterparts so there is some disadvantage there. Ford had lots of differant heads which can have a big effect on performance.The 390GT heads are fairly common and are decent altho 428CJ or 427 heads are much better. Stuff a 428 crank in it and you have a 410. A more agressive cam and exhaust are a must to wake up a FE.
luke Feb 5, 2011 03:54 PM
I see, he has factory heads on the car now so what your saying is keep on the look out for 428 or 427 heads and he can pick up a little HP. Thats good to know about the crank like a little factory stroker FE engine. I sent him the link to the forum and will also let him know about the cam he just got the headers
thanks for your time help
http://www.freeimagehosting.net/uplo...403aa165f2.jpg
MercuryDon Feb 5, 2011 04:04 PM
The 390GT heads are better than the run of the mill 390 heads but require GT Exh. manifolds. I see lots of those on ebay for sale. CJ and 427 heads are rarer and more pricy. For Aluminum heads try: http://www.edelbrock.com/automotive_.../6000/6007.pdf
luke Feb 8, 2011 05:58 PM
1 Attachment(s)
thank you MercuryDon and all for your time,
We got it
MercuryDon one last question if I may, do you know if thies Ford Galaxies are worth much all cleaned up?
Attachment 17149
Silverick Feb 8, 2011 06:25 PM
That will be a cool car, and that is a '64 Galaxie.
What part of the bay area are you in?
luke Feb 8, 2011 06:49 PM
Thanks:) Gabe and his car stay in San Mateo with nick(brother) and his cutlass that we did. I live with my girl redwood city and we have a her 65 mustang and my mopar.Point being I know you live around, we may move the cars to a warehouse Eastbay as we know the owners. If we do we may need a couple more people if you know anyone interested
thanks
MercuryDon Feb 8, 2011 07:00 PM
NADA Original MSRP $2,794 390 Total
Low Retail $4,325 +15% $4,973
Average Retail $7,875 +15% $9,056
High Retail $9,600 +15% $11,040
Silverick Feb 8, 2011 07:46 PM
Originally Posted by luke (Post 63301)
Thanks:) Gabe and his car stay in San Mateo with nick(brother) and his cutlass that we did. I live with my girl redwood city and we have a her 65 mustang and my mopar.Point being I know you live around, we may move the cars to a whorehouse Eastbay as we know the owners. If we do we may need a couple more people if you know anyone interested
thanks
I'm in San Mateo now. I think you meant 'warehouse'... maybe not! :rolleyes:
luke Feb 8, 2011 07:51 PM
Originally Posted by Silverick (Post 63305)
I'm in San Mateo but, I don't know about a "whorehouse" for my car! lol
oh man, good-look..... meant 'warehouse' got to love spell check sorry :o and to think of it why is Whorehouse in spell check.....lol
TVLynn Sep 30, 2016 08:16 PM
My thought would be that you are not getting the dampner on all the way.. I HAD A after market SFI dampner on a 360. Was a B to install. You need to heat it up in the oven before trying to install it.. USE the proper installer tool
Mr.4spd Oct 1, 2016 06:06 PM
I can't believe Iowan hasn't chimed in that you're responding to a 5 year old thread! Or that I'm responding to an almost 24 hour response! Perhaps he's on vacation?
TVLynn Oct 1, 2016 07:54 PM
I quite often don't check the date !!! My bad !
Mr.4spd Oct 2, 2016 02:50 PM
I know, I don't either. He busted me on one last month so I was just teasing. There are lots of old posts on this site, nothing wrong with replying to them
Iowan Oct 2, 2016 04:09 PM
I'm here and watching.:yikes:
