Mopar Forums (/forums/)
-   Non-Mopar Tech Questions (https://moparforums.com/forums/f67/)
-   -   I'll be the first i guess (https://moparforums.com/forums/f67/ill-first-i-guess-2530/)
crmzendrgone Mar 13, 2009 07:45 PM
My daily driver is a 1992 GMC Yukon GT 5.7L TBI and when ever i get it on the frreeway at speeds 80mph and above and then get off the freeway. As I sit on the off ramp I get a real strong smell of sulfer. this also accurs when i push it to those speeds in the early morning when n one else is around me. I believe it is running fat but i am not sure if i can adjust anything or if that is just how it runs. Curious if anyone may know. Thanks.
theomahamoparguy Mar 13, 2009 08:14 PM
Sounds like the catylitic convertor. Just a guess, I remember one going bad on a friends car, it smelled too. Dont know how to test it though. Pressure test ??? I dont know.
78D200 Mar 13, 2009 08:18 PM
sounds like you need a mopar for a dd.:p
crmzendrgone Mar 13, 2009 08:25 PM
that could be but i just had a high flow cat installed.
crmzendrgone Mar 13, 2009 08:26 PM
Isn't that the truth! I can surely tell you the next vehicle i get will be a MOPAR! Unless i can get my doba fixed then that solves everything:D
78D200 Mar 13, 2009 08:31 PM
tap on the cat and see if it rattles. I installed one on my j10 and had it last me about 6 hours. (thank you dead cylinder)
crmzendrgone Mar 13, 2009 08:36 PM
I will have to try that cause i know at idle it has been misfireing like crazy. I think it is time for a tune up.
theomahamoparguy Mar 13, 2009 08:55 PM
Uh-huh -yeah ....yessiree bob, 10-4, im withya'...
Polaradude Mar 14, 2009 03:07 AM
Most of us up here in the great white north view the catalytic converter as an obstruction to flow, conversely reducing some horse power, it is our view that things that reduce horsepower are to be removed at once and never replaced.:D
crmzendrgone Mar 14, 2009 09:45 AM
I did that just ran the exhaust from the y-pipes. but my beautiful little county i live in has emission test and they don't like vehicle that do not have cats. Trust me way better acceleration and definitely can feel the power difference.
Polaradude Mar 14, 2009 02:42 PM
shitty deal, I hate rules myself..lol:D
crmzendrgone Mar 14, 2009 03:33 PM
Yah. If i could own property outside of the county i live in and then register my truck to there i wouldn't have to worry.
johnthegoalie Mar 15, 2009 01:17 AM
as long as you have cats during the inspection...;)
Polaradude Mar 15, 2009 02:25 AM
Atta boy John, you know whats up bro...:D
67 GTX Mar 15, 2009 08:07 AM
haha
crmzendrgone Mar 15, 2009 06:11 PM
True very true but when i did that the wife felt it was a little to expensive to be doing that every too years. Unless i could figure out how to make it where i can just bolt it in.:D
Commando Mar 15, 2009 07:04 PM
What you can do as long as you can pass emissions inspection without them is to separate one in half, hollow it out and bolt it over top of the exhaust.
johnthegoalie Mar 15, 2009 08:18 PM
if they find a gutted cat, they will flip their biscuit... big fines for that
crmzendrgone Mar 15, 2009 09:23 PM
Yah i know but i wonder if i could just weld connecting plates or something on each end and bolt them together or something like that.
johnthegoalie Mar 15, 2009 09:30 PM
thats what a buddy of mine did, a flange on both end of the cat and a piece of straight pipe the same legnth with flanges. 4 bolts and it was ready for the rollers. if i remember right he had to weld a bung in the straight pipe for the oxygen sensor
Commando Mar 16, 2009 06:48 AM
All they got here is a mirror on a stick, so if it looks good from 6 feet away then it should be fine. But I pulled mine long ago, and use private inspection stations that really don't care about mods. Also someone was telling me about combination cat muffler and all you had to do was produce the paperwork for it and they let you go, not sure if this works but that's what I heard.
