Not sure what kind of rims I have.
1 Attachment(s)
so I have the day off tomorrow and want to clean my car a bit. My rims neeed some attention so I wanted to go and get the correct cleaner and what not I need. Dammit. Not sure how to post pics
Soap and water and some good old elbow grease should do it.... :)
Welcome to the site... :) Look under avatar and pictures... |
(Post 139038)
(Post 139038)
Ya,,, Fuel mileage is becoming more of an issue now days.... The fuel we get just doesn't go as far as it use too. The 2 barrel is still your best bet for mileage.. No more that an RV cam are as far as cams go for that. But thats just my 2 cents.
But if you have to or looking to up grade... Sill go a small rv cam and maybe a holley 650cfm or 770 street avenger. Only use a vacuum secondary carb. But if your getting like 12-16 MPG... Your not doing all so bad... Now if its down to around 8-9MPG... You got room for improvement. Good Luck on the wheel cleaning... Hope they look nice when your done.. :) |
Simple Green is a good all around cleaner for those rims. I use it for a lot of projects around the house. It cuts road grime pretty good. A small four barrel carb will be good as long as you keep your foot out of it. The aftermarket throttle body systems are good too. I am trying to convince myself to upgrade to that but I am a tightwad and cant pry open the wallet.
Any paint safe weel cleaner will work, then letter rip tatter chip. Hahaha:)
